Normal? or something to get checked? Fatboy2006
Old 08-28-2006 | 08:25 PM
Bikemeup's Avatar
Bikemeup
Default Normal? or something to get checked? Fatboy2006
Happened a few times curious mind want to know...
Park in my same underground Parking spot daily... sometimes back in first sometimes front in first... happened a few tiems on the road bust mostly when i do this...
Parked front end in:
- get to the bike give the standard look around to see how kewl the ride ride looks
- unlock it blablabla
- put it in Neutral (making sure N light is on) to back her out enough to be ready to head straight out when rdy...
- Start the bike (EFI)
- have a last check everything seems right
- put her in 1st gear, heard to shift noise so must be (made sure green N light was OFF)
- give her some trottle to get her going...
IT"S NOT IN 1ST GEAR but there is no N neutral green light on... and yeah it is STILL in neutral!!! WTF? double check that the green light is not on it aint.. push down again to make sure it's in 1st even if there is no green N light on, try agian now it's in 1st... and she wants to go...
so am i the only one who experience this? it happens at stop lights/signs from time to time too...
Old 08-28-2006 | 08:56 PM
mudrat_fat05's Avatar
mudrat_fat05
Default RE: Normal? or something to get checked? Fatboy2006
Happens to my Fatty once in a while too. I just shrug it off to not hitting the shifter hard enough
Old 08-28-2006 | 09:52 PM
FLSTCI nut's Avatar
FLSTCI nut
Happens to me too sometimes. Don't really know what it is either just something that happens.
Old 08-28-2006 | 10:05 PM
Mike05's Avatar
Mike05
Same here. I can usually tell by the clunk if it really went into gear. Only does it when it's cold. Maybe the lube just needs to slosh around a bit.
Old 08-28-2006 | 10:12 PM
dadofsix's Avatar
dadofsix
It happens to me as well. I didn't realize this problem was exclusive to fatties. No problens with a hard shift -- like when downshifting. But in a gentle shift into first - like when you drift into a red light in second waiting for the light to change, and then realize that you have to stop completely. It's a bitch to then shift it into first. That said, it's still the greatest bike on the road!
Old 08-28-2006 | 10:51 PM
Bikemeup's Avatar
Bikemeup
Positives way outweight the negatives here too! Fattilove!
Old 08-28-2006 | 10:55 PM
wildman67's Avatar
wildman67
happens all the time(not shifting hard enough!) happens when i am downshifting sometimes when i go from 2nd to 1st if i dont shift hard enough it makes a funny noise and hangs up in neutral
Old 08-28-2006 | 11:09 PM
Bikemeup's Avatar
Bikemeup
Bbut NO Neutral green light????
Old 08-29-2006 | 01:17 AM
wildman67's Avatar
wildman67
Yup looks the same I think i am in gear no light but I am not!
Old 08-29-2006 | 01:44 AM
Jeff Brokenshire's Avatar
Jeff Brokenshire
You have probably moved the gear lever down far enough to turn the light off, but not far enough to engage gear. It is all pretty normal. Maybe check your gear lever position whilst the bike is not running and see how low it goes before engaging and it is not hitting anything on at its bottom position. Click 1 notch upward on the spline of your front lever, if you think it is too low, and all should be fine.
Quick Reply: Normal? or something to get checked? Fatboy2006
