Model A Tail Lamp on Softail Questions
Hey ALL,
I have seen a number of folks running this style of light on their softails, mostly in conjunction with some sort of side mounted tag mount. I was hoping you guys could fill me in on how you have yours operating. In the picture below, the lamp actually runs two separate single element bulbs. Do you guys wire it so that one bulb operates as a running light and the other as only a stop light? Any input would be appreciated.
I am aware that they are not DOT. I wonder what about them makes them non-DOT? The amount of light maybe?
The ones I plan on running are not the smaller kind that are pretty popular, especially as side mounted lights. Those are usually not much more than 3" in diameter if that. These are reproduction lights which are almost 4" around. Additionally, I don't plan on this being the only light behind me so hopefully I won't suffer from any lack of night time visibility.
Anyhow...appreciate the feedback and concern.
Are the bulbs single or dual filament?
My guess is single...
I would wire the bottom as a running light and the bulb over the "Stop" as a brake light...
as far as being seen.... I bought a controller so my turns act as run/stop lights....
it helps...as they are brighter as stop lights than my led bulb in my tail light...
CC
CC
CC
CC
I have the run/stop/turn module in my Bones now so I actually have a number of options for rear lighting. I wonder if I can change the sockets out for dual filament? I found a sight that sells the sockets for these style lights. Just not sure how easy a mod it would be! Guess I won't know until I try it!
Have you thought about what your going to do with the old taillight/ fender? or is this an addition....
CC
I did it once.... I had ordered a pair of turns...to replace a pair of old ones... I messed up and ordered singles...I just took the old doubles and swapped them with the singles.... If memory serves me right there was some soldering /desoldering involved....
CC
CC
I replaced the stock rear fender for a Fatboy Lo and I am doing a custom setup with a couple of these as apposed to using the stock Fatboy light. Not sure yet what I am going to do with the old fender and light assembly. I may keep the fender and chop it just to try that out sometime or sell it if someone would be interested.
