Sylvania H6024 Alternatives?
Hello from the Dyna forum
I recently picked a FatBoy 7" headlight in great condition on eBay. The housing uses the H6024 sealed beam. I've done a bit of searching but have not found a definitive answer to what the best type of replacement sealed beam would be for the H6024.
Any input would be great.
Thanks
Thanks
you will have to get a lens to replace the sealed beam if you want to use a bulb. you can get the lens new or used. I have a harley lens just sitting around as i got a bosh euro vw lens used for $20. best pattern for driving.
http://www.ratwell.com/technical/BoschH4.html
Is this the lens you replaced yours with? What type of bulb did you decide to use? I guess at this point once you've replaced the lens, there are many more bulb types to chose from.
tk,
H4 SUPER PLASMA GT-X ANTI VIBRATION - TWIN BEAM
http://www.piaa.com/Powersports/bulbs.html
beam, beams, bulb, h6024, harley, headlight, headlights, housing, light, motorcycle, motorcycles, rplace, sealed, sylvania, walmart
