brake light stays on
Whats up I have a 2005 Fatboy that I recently got painted and for so reason now my brake light is always on when the key is turn on to the on position. Ive check bulbs and plugs and every thing was put from where I took it off when I disassembled it. Would any one have any suggestions. Also when i put the rear fender on i noticed the gap in between the tire and fender were off the right side i can stick my fingers though and the left side I cant is that normal
Not sure if it's the same with the softails, but when I had my Sportster I had the same problem. When the brake lever is at rest, there is a tab on it that presses on a button in the hand control assembly which shuts off the brake light. When you press the brake lever, the tab on it moves away and doesn't press on the button anymore which then turns on the brake light. For my Sportster the tab fell out somehow, and the button was constantly not pressed in and so my brake light was always one. I super-glued a small tab which I cut from an old credit card onto the inside of the lever to press on the button while the brake lever was at rest. Worked for the next year or so while I still had the bike.
Again, not sure if softails are the same.
Like others have said, it sounds like the switch at the brake lever. This is easily damaged and is an expensive little switch ($30 or so). They are easy to rip the rubber protective covering off of and over time the switch corrodes. My thoughts are either they damaged it while putting the bike back together or it was ripped previously and some paint shop supplies have gotten in there and caused it to fail.
but, I am sure he would chime in to say the switch housing was bad. if he even owns the bike anymore.
