Rear Brake Pedal Clevis Pin Removal
I got Clevis Pin out with a bunch of jiggery pokery only to find the stock brake pedal stuck on its shaft. I wanted to change to the billet pedal from stock so I decided to avoid the hassle and rode to the dealer. Their tech swapped the pedals out and I only had to pay 1/2 hour labor. I considered that a bargain considering the hassle of dealing with that little pin.
My harbor freight tool to remove clevis pin
Fought with this for a couple hours and found this old thread... hope this will help someone else.
$3 clamp and a socket did the trick, i found electrical tape did the trick to hold the socket on the clamp. Keep turning, It will make a pop and come right out.
as they say, install is the reverse of removal
Removal
Reconfigured to re install
In process
Removal
In process
FloridaRider
10-15-2008 08:04 PM
