rear axle torque
06-28-2010 | 02:26 PM
rear axle torque
Does anybody know what the torque value for the rear axial for a 07 softail?
Thanks ahead of time
06-28-2010 | 03:51 PM
My 06 is 60 to 65 ft lbs.
06-28-2010 | 05:37 PM
the manual for my 07 also states 60-65 lbs
06-28-2010 | 05:41 PM
The Rocker is 90-105, because they make so much more power than all the other softies.
06-28-2010 | 05:46 PM
Quote:
Originally Posted by
mobsters1972
Because of some varibles I would try 60-65 ft lbs and then maybe back off a little.
06-28-2010 | 05:47 PM
Ruralmed
might have something to do with that heavy, power robbing, fat *** rear tire. :-) . but they do look cool.
Ruralmed
Wow you may need wheel bearings in a few thousand miles.
06-29-2010 | 12:04 AM
Rockyriver
Well, I have 14k so far...no signs of failure yet. Actually, the softail manual recommends that torque spec for the Rocker. I have no idea why it needs another 30ft/lbs. Heavier wheel and tire creating more rotational weight perhaps?
06-29-2010 | 12:16 AM
i like your 1st answer best ru
06-29-2010 | 07:57 PM
Funny you should mention the Wheel Bearings.....
When I upgraded to my 250 rear and had the Wheel rebalanced, both the bearings were SEIZED, complete failure at 3400 miles!! Added $150 to my otherwise inexpensive 250 Elite3! When I reinstalled the tire I brought my torque setting to 95ft/lbs and settled there.
NewfieRocker
GittinThere
10-03-2022 03:53 PM
wing-nut50
04-10-2022 04:24 PM
clap
02-21-2015 07:01 PM
RocketRocker
06-28-2009 10:56 PM
Nitram
09-15-2007 11:34 AM
05 ,
2006 ,
95 ,
axle ,
davidson ,
fatboy ,
ft ,
harley ,
rear ,
rocker ,
softail ,
spec ,
specs ,
standard ,
tire ,
torque
