Turn signal popping fuse! Suggtestions?
My buddies bike is popping a fuse every time he hits the right signals. We recently rewired his bars when he added the Carlini's. I assume that maybe there is a bar wire inside the bars that is touching metal. I opened the switch housing on the road and all looks well in there. His rear signal is wired inside the channel of the struts so we were unable to check that on the road, but he was also telling me he just twisted the wires together and taped them so that could be a culprit as well.
Obviously it is a wire grounding out, I am hoping I don't have to take the bars apart again, but i wired them so I will fix them. Any other suggestions I may have overlooked?
When the accessory fuse pops the speedo goes dead and the brake light goes out as well. The code is p1097 which is for the speedo going out. The bike is a 2005 Fatboy with about 30K miles. I thought crank position sensor until I found a blown fuse.
Thanks!
Drew
Thanks!
Drew
Thanks!
Drew
Thanks!
Drew
Drew this may suck to do but can you get to the connector under the tank on the right side? if you unplug it there and locate the proper colored wire that runs to the switched side of the turn signal switch. Take a electrical meter and set it to continuity or ohms and touch one lead to the bike frame or ground and the other to wire that runs through the bars. If it rings you no the ground fault is in the bars. If not it will be in the rear of the bike. That is how I would do it. You know its in the bars! It probably is right at the drilled bar opening inside the switch box or the opening between the risers. openings in the bars are a perfect place for a ground fault.
