Thundermax again...
Old 06-08-2010 | 12:19 AM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
Default Thundermax again...
I got a raise today at one of my jobs (WooHoo!) so I might be able to get a Thundermax with Auto Tune. Who has one and is it worth it. Is there anyone that switched from a power commander to a Thundermax? My fatcat has the 02 sensor ports so from what I gather I just plug it in (the whole new ECM and autotune module), load the map and it does the rest? Talk me into it people. My bike is an older 2002 EFI. It runs what I consider to be great but I am sure it can still run better.
Drew
Old 06-08-2010 | 01:07 AM
JayDee5150's Avatar
JayDee5150
I've heard nothing but good things about it D...don't think you can go wrong with it.
Old 06-08-2010 | 06:22 AM
texas-buzzard's Avatar
texas-buzzard
since you already have the O2 ports, it's plug and play for you. i've been running one since my 10 fxstc was new and have not regretted the change. the software is easy to use and you are able to change any the A/F parameters from idle to full throttle. the install took about 20 min. you can find them a little cheaper on e-bay.
Old 06-08-2010 | 08:06 AM
mplecha's Avatar
mplecha
if you have a good map for the pciii, I'd stick with that. I don't think it will make your bike run any better than a dyno tune. I used to have a power commander 3 on my bike before I got the thundermax. It's nice, but it's not perfect. Is it worth $8-900 - maybe.
Old 06-08-2010 | 08:23 AM
tk353's Avatar
tk353
i went from pclll to TM. i can say the pclll was great after the dyno tune. the TM seems to be all around better as it will adjust for weight, wind, weather and yes even sucking in water (not recommended). one thing it does do well is gives you the opportunity to change your engine around and save the expense of another dyno tune. i have about 40k on mine and minimal issues. I did need to change 1 o2 sensor out because it had a bad wire but that could have been because i got it used. i tried a few maps to see what would the difference be and TM was right when they told me to use the 2 into 2 exhaust map. they say the important part is to pick what is closest to the bike you have and then the TM will adjust from there. You can download the software and see what maps they have before you buy it. I use the 393 map and leaned out the 30% and higher setting.
Old 06-08-2010 | 08:40 AM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
Thanks for the info guys. Thundermax is not inexpensive. I'll have to think on this a while.
Drew
Old 06-08-2010 | 08:46 AM
tk353's Avatar
tk353
got mine used in the forums classified for about $450
Old 06-08-2010 | 08:53 AM
Colin1966's Avatar
Colin1966
I use the Thundermax and very happy with it.
My thinking when I picked it up was, if I do any work to the bike it will need to be tuned so why not get something that's going to save me $$$ in the long run.
Colin
Old 06-08-2010 | 08:54 AM
Ultra Street Jewell's Avatar
Ultra Street Jewell
Just put the ThunderMax on my 2010Ultra Limited with the Vance & Hines Power Duals. I am very impressed with the over all performance and sound coming from the twin slash 2 in 1 slip ons
Old 06-08-2010 | 07:02 PM
WoodsHog's Avatar
WoodsHog
Go for it Drew.Its worth it.You should be able to get a good price on one.
Quick Reply: Thundermax again...
