My samson's seem uneven???
I just put some samson s-433 true dual fishtail exhaust on my 2000 Softail. The install seem to go very easy and every seems to work fine. Upon its maiden voyage, my buddies noticed that they are uneven in back. The primary side seems to be about 3/4" to 1" lower than the other side.
Has anyone else ran into this? Is there something i could have overlooked on the install? (I plan to call samson tomorrow, but wondered if anyone else had noticed the same issue?)
Any ideas?
Kramer
Any ideas?
Kramer
I've had two sets of Samson True Duals over the years and had to do this on both sets.
You might get away with just loosening up the brackets that bolt to the mufflers, at the frame, and pull the low side up and push the high side down to the maximum amount and tighten them up.
You might only be an 1/8 to 1/4 inch off this way, not noticeable unless you really pick the bike apart...and saves your from loosening all your clamps and connections.
I'd try that first.
My pipes are about 1/4 inch off in height from the back tip of the fishtail to the ground with the bike is sitting perfectly straight. The right side is a little higher than the left (primary) side. I've attached a couple pictures of the bike from the back so that you can see it's really hard to tell the difference once you get 1/4 inch or closer to the same height.
Any ideas?
Kramer
Any ideas?
Kramer
JR
