I picked up 2 filament front turn signals to put on rear of bike .Will buy red lense covers to install on them.My question is with twin filament turn signals what would be the best way to install them ? With a spliter or module ? If a module is best what brand works with an '06 with a H-D alarm system. Thanks in advance.
If you're going to use the integration module I don't believe you needed to change anything on the lights. The module will totally control the single element lights that are on there. If you want to do 'dual element' you just need to wire them up for whatever you want them to do.
If you go with a module use a badlander. They are kind of the original when it comes to run/turn/brake controllers ect... Just installed mine, literally just unpluged my lights and plugged them into the module and was done. To easy!
I have the HD module and it could not have been simpler. Plug in change the lens and your done. I had one on a 04 Fatboy and moved it to my 2010 Heritage, no problem. Haven't had a problem out of the one I put on my wife's sporster either.
+1 on the hd module. takes about 15 mins. to install. plug-n-play. comes with red lenses. i've had mine on for several years....never a problem. @ $45 from dealership. steve
