12" Fat Mini-apes for my Fat Boy
I'll be putting these on shortly.
Couple questions:
1. How difficult is this job? I'm very handy and have a decent array of tools.
Stealer quoted 8 hours ($625.00) just for the labor. WTF?!?!
No f#$% way am I payin that to change handlebars!
2. The HD site isnt exactly clear on exactly which part numbers are for the additional parts needed. they say "Not availalble" for the brake lines, and for the switch wire and signal wire extensions they just list a length in inces but no part numbers.
I dont want anything fancy or expensive. Just regular OEM parts, cables, wires, and hoses.
anyone have a straight up tutorial on how to do this upgrade, and a list of the other parts I'll need?
Thanks!
Couple questions:
Thanks!
Should be able to do it yourself. You will need to disconnect everything from the gas tank except the front crossover line and then you will be able to pull the tank back far enough to access all of the wires you will need. Then just take your time. If you do not have a manual yet go buy one with the $600 they are planning to charge you. Good Luck and remember if you get stuck post on here someone will have answers.
