Belt Change
05-28-2010, 12:05 PM
You are right. Hadn't thought about that axis tube. As you can tell, I have not done this, but had looked at it for future reference. Missed that tube all together. Now I know. Thanks. Always learning something new on here.
02-23-2012, 12:57 AM
Quote:
Originally Posted by
hspring03
The swingarm axle and spacer have to be backed out so the belt can go on.......The swingarm does not have to come completely out.
I'm doing the 30T pulley mod to my 07 FXSTC, and I'm at this step right now, trying to get the old belt off.
Is there anything I need to know when removing the swing arm axle & spacer?
Are there any parts that should be replaced 'while I'm in there'?
Thanks
02-23-2012, 07:13 AM
drspencer
Thanks
There's not parts to replace on the swingarm axle and spacer. Just back them out enough to slip the belt past.
The real job is the inner/outer primary and clutch hub assembly.
Neil
10-10-2019 08:45 PM
bonesmutley
Shovelhead
11-17-2013 07:29 PM
04-23-2012 06:36 PM
jughead4885
Shovelhead
15
01-14-2010 06:05 PM
kisskrazy
04-18-2005 11:57 PM
07 ,
belt ,
change ,
fix ,
harley ,
lehman ,
motorcycle ,
pictures ,
rear ,
replace ,
replacing ,
rocker ,
shovelhead ,
shredded ,
softail ,
trike
