Neutral light does not always come on
![Question](https://www.hdforums.com/forum/images/icons/icon5.gif)
So i got frustrated the other day, been having a hard time finding neutral, at least that's what i first thought as the light was not coming on, so i fiddled around over and over again, all the way up and back down thinking something was jammed, kept feeling the little click but no light, than i said this is crazy feels like its in N, so i slowly let go of the clutch and I was correct, in N but no green light, its happened quite a few times, and sometimes the light does come on, what can it be? Thanks gang for responses!
A couple of possibilities, sticking switch or loose connection. What I would do is the next time it happens I would stop right there and locate the wires which go to the switch on top of the transmission and wiggle and push on them to see if that makes the light come on, if not, then I would wiggle the wires at the indicator light, still nothing?, then try lightly tapping on the neutral switch to see if it is stuck. One of these should diagnose yor problem to the source then the repair will be easy.
