Plug Wire Help pls.
Plug Wire Help pls.
I have an '04 Heritage Classic
I wanted coloured plug wires so I ordered Accels ...then tried SE wires.
Both sets of wires make the engine light come on and I get the code..
P1353 Front Cylinder No Cumbustion EFI
( The code is not accurate because the bike is working fine....but the engine light stays on. )
When I clear the code and put my stock wires back on....the problem goes away.
Now I have a blue set of Accels and a red set of SE wires but can't use them. ( can't ride with the engine light on all the time. )
I'd appreciate any comments.....thanks
I think you need different wires. Here is a set that will work.
http://www.drvtwin.com/eshopprod_cat...HROMITE174.htm
The Acells (sp?) were 'supposedly' made for my bike.....didn't work
Parts manager at local dealer.. guaranteed me the SE wires would be good....didn't work.
I will probably still order the ones you suggest, ( 3rd. attempt )
thanks,
thanks but now I'm gun-shy about buying another set.
thanks,
thanks,
Drew
coop57
05-07-2008 05:18 PM
