Rocker C ~~ rear ~ tail, turn indicator HELP
I have a 2008 Rocker C and I have moved the license plate to a side mount and purchased the auto gem baby bullets for the rear indicators, the baby bullets have 3 wires to each light.... the stock wiring harness had 4 wires to each tail light. and i tried to wire the baby bullets direct from stock harness and i dont have any rear tail lights, the brake lights work, blinkers flash normal speed for the first few flashes then they go fast.... i bought the Kurayken rear run turn brake module part #4859 and was told that is a plug and play... however it didnt plug into harness on bike so i returned that. NOW i have same problem again~~~~ need to firgure this out, do i need to buy some different taillights? that have 4 wires? any help would be great~~~~~~~~~
Thanks in advance
Thanks in advance
Update~~~
all is working now with the exception of the tail light, leke when riding at night... blinkers are working correctly and the brake lights are working.
stock harness has 4 wires~~~ red, green, black and white~~~~ only one im not presently using is white which is the tail light wire~~~ how do i incorporate that in?
is i have 3 wires coming off of the tail lights, with this module will that take care of this? the present harness has 4 wires
