Rocker C ~~ rear ~ tail, turn indicator HELP
Old 10-23-2010, 04:08 PM
lazyboy09's Avatar
lazyboy09
lazyboy09 is offline
The badlands kit is a direct plug and play setup. Very high quality. If I remember correctly, you wire the 2 power wires from the lights to the green wire in the harness the module takes care of the functions by varying the power to the lights. The instructions are very easy to follow.
I'm running Headwinds lights with this module.
Old 10-23-2010, 04:18 PM
lazyboy09's Avatar
lazyboy09
I didn't notice the dates on this thread. @ skullwizard, I assume you have your light issue straightened out. If not, I hope that helped. @ biker1 are you looking for specific lights or help with the function issue for aftermarket lights?
Old 05-10-2013, 02:29 PM
BayCitySmitty's Avatar
BayCitySmitty
BayCitySmitty is offline
Stage II
Default Did you find an answer to your problem?
I am having the same issue, what did you do to solve the problem?
doggin_it
09-12-2022 10:10 AM
DaddyKnuck
05-31-2017 09:57 PM
Matthew Wallace
07-22-2014 07:29 PM
NightTrainRob
10-27-2008 08:09 PM
magnoliarunner
01-17-2007 10:01 PM
Quick Reply: Rocker C ~~ rear ~ tail, turn indicator HELP
