2010 Fatboy Lo leaning forward too much
Okay just talked to the dealership and am not ready to stomach a 1500-2000 bill to swap to apes... so i'm going to hopefully opt for a cheaper route until i can save up the money.
How much rise/stretch can i put on the bike (new risers) and still keep all of the same cables?
I was looking at the brake line cable and it seems to be screwed into the forks which makes it look tight so if i unscrewed it it would be loose and i could pull it back further. Same with the throttle cables.
Has anyone gone this route? I've read with mid 2000's fatboys people could put a 4.5" up and back riser on the bike with no problems and all with stock cables.
Any pictures and advice would help but i've got to do something in the mean time while i save for the apes.
Thanks!
Rumblestrip
Thanks!
Rumblestrip
I want some 14" apes on my bike too bud, Night Train drags are starting to wear on me a little.
I plan on doing it myself, but don't want to spend the cash till I'm sure it's for me.
What I did was swap some pegs I had for another members stock Street Bob bars and all his stock cables. I don't have them yet, but I should be able to get the swap done to the 10" bars for the price of powdercoating and some new crush washers.
If you go the way I'm doing it, you could throw on some stock "mini ape's" for $50 or so. I've never done it, but have a manual and some free time so what the hell.
Good luck!
Good luck!
I had them swing the bars back when i bought it but it's still not enough to be comfortable. I'm going to try the 6" pullback risers and see how that goes. Worst case i'll have to get an extention for the wiring. The cables all look like there will be enough play in them. That should get it plenty comfortable until i decide to buy all the parts and put the apes on it.
I didn't know that there was a plug and play wire made for it. That's helpful, i thought i was going to have to cut/splice/and solder all those wires to extend them! that would have sucked!
I'm going to have to get a manual, and i'm guessing the manual that ya'll are talking about isn't the one that came with the bike?
Thanks!
Thanks!
I'm having the Street slammers put on this week and I have talked to 3 ppl in this forum about the process.
Looks like the only cable you have to change is the Brake cable going with the street slammers. They have integrated 7" risers.
I'm doing the clutch and T/I also just because I want to go with the diamondblack.
Should have some pictures by the end of the week or early next week. Putting the street slammers on and the black lower forks. Should finish my major mods.
When i was looking at the cable lengths and so on, the front brake cable screws into the back of the front forks. I was thinking if you unscrewed that, then you should have enough play in the cable to be able to do it without replacing it. When you go to put everything on, woudl it be too much to ask for you to check and see if that will work without swapping out the cable? If it ended up working it could save you 50$ or so too... I don't want to order a new cable and go through the process if i don't have to. I am checking out the street slammers though, they seem pretty nice.
Wynchester
12-08-2014 07:06 PM
