Riser problem with Burly narrow apes?
My wife bought be 14 inch Burly apes for my birthday. I also got 2 inch smooth top risers from Joker Machine. I'm working on getting it all installed and when tightening down the tops of each riser over the bars, I'm ending up with about 1/16 inch gap between the top clamp and the bottom. Anybody else have a similar problem with Burly apes? My only other thought is that the risers are slightly too wide for the narrow bottom apes and are hitting where the bars start to curve up and so won't tighten down all the way. I'll see if I can get some pictures tomorrow.
I'm at work, so cant go check my manual but I'm pretty sure that there is supposed to be a SMALL gap if you evenly torque your riser clamp.
I'd have to go look, but I think there's a small gap on both my HD's.
I always assumed that if the riser clamp was bolting completely flush on all mating surfaces that you'd be torquing the clamp into the risers and not putting the torque on holding the bars.
The pro's will chime in, but if not I'll check the manual when I get home. Good luck!
What diameter bars and what diameter risers...have to ask, I'm sure you cover that base but you just never know and did they send the correct part #'s cause it sure sounds like the bars and the risers are not same size. All risers will have a small gap tightened down. After re-reading sound like a bar prob. Bars too narrow made for another application? Knurling would be the tell tale if they are knurled.
You can tighten the front clamp bolts first to hide it, but then you'll have it in the rear.
I loosely tighten the rear first then tighten the front bolts.
Small gap in the front and it is totally normal.
The Carlini risers and BR's aggressive knurling didn't really need the hidden set screw in the risers, but it's a nice feature anyway.
