Break In
Break In
Ok guys I have heard alot of differany stories about this.
1. Do not run your new bike above 3500 rpm and not above 60 mph for the first 100 to 500 miles.
2. Ride it like your gonna ride it, but dont peg the rpms or spedo for the first 500 miles. ( not that Id do that )
So what are your opinions?
Thanks Kirk
Thanks Kirk
RE: Break In
I have been riding at differant speeds and havent hammered it or rode like a nut. I did crank her up to 90 for a few seconds. I try not to wind her to tight, I have 370 miles on her and havent ran her hard. I just heard differant opinions and didnt know what to believe, one Harley mechanic told me to run it the way I want and a Harley Salesman said to take it easy.
RE: Break In
I realize that there are several opinions as how to break in a new bike. The easiest way for me to figure out which one to follow was to simply follow what my manual said. It saved a lot of confusion on my part and I figured if I followed what the book had to say and I had problems, I could say that I was following the manual and HD would take care of the rest. Works for me. Hope that this helps you a little.
RE: Break In
Here's a couple of links to breakin proceedures that do work
http://www.mototuneusa.com/break_in_secrets.htm
http://www.hastingsmfg.com/Service%2..._procedure.htm
http://www.lycoming.textron.com/main...neBreakIn.html
My theory is this,
Ride it the way you rid normally with no high RPM starts BUT, don't baby it. Most of the break in is done in the first 50 miles and if the rings aren't seated with some power bursts, you will have an oil burner on your hands. You need the compression pressures that force the rings out to seat them properly and you don't get this by babying it. This is how my bikes have been broken in and all run exceptionally well and do not use any oil.
My theory is this,
