Rear Suspension Bouncy?
Hey All,
My wife was complaining that riding on the back was making her kind of sick from the "bounciness". I'm on an '06 FLSTSC with about 1200 miles in.
Does that mean the rear suspension is too soft or too stiff? What can I do to make the ride better for her (aside from buying a another bike [8D])?
I've been doing some searching but hadn't come across a solid answer to that yet.
Thanks!
Thanks!
RE: Rear Suspension Bouncy?
Too new for suspension problems.They come with a factory preload for a certain wt.person.I dont think it considers two-up riding. Has it been lowered ? (would make it only stiffer).You can always go with an after market shock like Progressive.Not much else you can do.Personal choice I guess or live with it.
Suggest you ask Harley to set the shocks for the combined weight of you and your wife. I have the same problem, tried to set the shocks myself and was not able the turn the preload.
Also you have to watch to make sure both shocks are set the same. If one is off or not working correctly it can cause handling issues.
Two up riding requires a 40 psi rear tire pressure and 36 front according to the manual, and yes, tire pressure makes a big difference.
My bike is grounding on driveway entrances, gate entrances with two folks on the bike. Wife weighs 125 and I weigh 200 so the shocks need to be set a bit stiffer than stock.
Hope this helps.
Lee
Hope this helps.
Lee
The lift you have is standard. The shocks are simple enough.You should get instructions with the shocks.There are only 4 bolts involved.The old ones are probably pretty darn tight/factory loctite and may be a booger to get off....muscle.Take a look underneath to determine if you want to tackle it first,but as I said it is an easy job.The frame supports on the lift may make things pretty tight .2 bolts on the swing arm and 2 on the frame..The new shock s will have to be compressed and any compressing tool is advised .Can be rented from most parts stores.Similar to putting gas shocks on a vehicle.The last progressives I bought came with a compressing band and all is needed is cut it off once then shocks are installed.
