Perfect solution to slipping bars!
Old 05-06-2010 | 10:02 PM
rowdy82's Avatar
rowdy82
Default Perfect solution to slipping bars!
Alright guys, i read 3 thousand different ways to keep your apes from slipping and found one better. Called Skid Guard Safety Tape from Lowes. Its the same stuff you put down on concrete steps that give them the rough texture so you dont slip. The back has adhesive on it so it sticks to the bars and the part that makes contact with the risers is like coarse grit sandpaper. Just did this to my Crossbones with 16" Nash Gimps and torqued them down to 15lbs and i cant get them to budge at all. Try it out, $4 for a roll of this stuff...
Old 05-07-2010 | 04:17 AM
bare_knuckles's Avatar
bare_knuckles
How long has the tape been on
just wondering if the adhesive will heat up in the sun and loose its grip?
Old 05-07-2010 | 11:03 AM
rowdy82's Avatar
rowdy82
just put it on but this stuff is made to stick to concrete and boat docks so it should hold up pretty well. Will update if i run into problems with it
Old 05-07-2010 | 11:58 AM
chad pickens's Avatar
chad pickens
I have done something similar and it worked well for me I take a piece of sandpaper and fold it rough side out on both sides and stick between the bars and risers. in all the times Ive used it it has never failed me
Old 05-07-2010 | 12:25 PM
hspring03's Avatar
hspring03
I just tried this the other day.... I already noticed how much better they are...
Old 05-07-2010 | 01:34 PM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
Something new for me to try. And, we have a roll of that stuff laying around my building somewhere. The funny thing is the way I have them now they have not slipped in ages. Drew
Old 05-07-2010 | 03:00 PM
rowdy82's Avatar
rowdy82
they werent bad if i cranked them down but after i stripped the riser i decided i had to do something different. Seems to take up just enough space to keep them snug and give them a little texture too
Old 05-07-2010 | 07:02 PM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
Helicoil the riser too. It does a lot for how tight you can crank the bolts down.
Old 05-07-2010 | 09:31 PM
97Rob's Avatar
97Rob
lock tight
Old 05-07-2010 | 09:48 PM
rowdy82's Avatar
rowdy82
Actually did run a helicoil in it. I was half tempted to just helicoil all 4 now before they have a chance to strip out, haha
Quick Reply: Perfect solution to slipping bars!
