Is this cam a good choice for my bike??
#31
#33
I spent alot of time looking up cams and making a pain in the *** of myself asking every person that might know something questions. What I found was you can get away with a slightly larger bolt in cam and not loose bottom end power with the right tune. Ya, it would be even better with higher compression but still much better then stock across the whole RPM range. A good tuner working the dyno is the key.
#34
- TW6-6 +4* adv gear
- Andrews new 48H (like the SE255 but better)
- TW5-6
- Andrews 54H + 4* adv (might be too much cam for stock top end)
#35
Thanks Mike06train...... So in my case, running true duals, what would you consider a slightly bigger bolt in cam??? So far all my research leads me to the following:-
- TW5-6
#36
#37
#38
My advice is to call Gary Wallace at Andrews and he'll make a recommendation based on your engine, intake, exhaust and riding style. When it comes to cams, there are several different manufacturers that offer a cam that will suit your needs. Gary Wallace,Technical Support,Andrews Products, Inc.,847 759-0190 Ext. 38
#39
I think the pipes make a HUGE difference too.... Like I am running a true dual system and compared to a good 2-1 pipe I will be losing lots of low end power..... so this needs to be considered carefully when choosing the cam. The one piece of advice I keep getting is that performance components have to match each other to perform well.
#40
So I guess it just comes down to how I want to ride the bike....
