detachables with easy brackets
hi,
Ive a detachable sissy bar setup on my 2006 fatboy(last of the truly solid wheel models) If I buy the easy brackets, does the existing HD fender rail mounting hardware become redundant and get replaced with the easy bracket kit?
Also, please can anyone recommend any bags - Ive got the stock pipes with slip on screaming eagle mufflers which give a bit of a constrint with space?
Thanks, Matt
Thanks, Matt
easy brackets are ordered according to the hardware you already have. if you have detachable from HD then you get the longer bolts and hardware from easy brackets so you use both. i went with the forward mount brackets so i would not have to relocate the turn signals. i also modify the HD side places so i could keep the same turn signals mount
JRK5892
04-24-2009 12:37 AM
