engine light..?
"Get the 'Screamin Eagle' 10mm wires. That will fix your problem like it did mine as I did almost the same thing you did."
You say the Accells worked for you and yet they are the wires that caused a prob. for me. ...???
On tuesday I will get the SE wires and try them...( I'll post to let you know how they work for me. )
thanks for the comments,
Interesting....SportyReb ( above comment ) says;
Maybe they have changed the SE to be compatible also.
I have a set of SE's in my tool box in red if anyone wants them PM me.
Does that code need to be cleared in some way or will the light not come on if it fixed the problem? I will let you know if it still comes on?
I got a Blue pair of Accells last week from J&P Cycles and they were Delghi compatible too, but as soon as I road about a mile from my house the check engine light came on. I rode to the Harley shop yesterday and they had a red pair of Screaming Eagle wires in stock. I put them on last night. Going on a good long ride this afternoon so I'm hoping the light stays off.
The Screaming Eagle wires did the trick.
