Front forks extremely STIFF!!
If I hit the tiniest of bumps it feels like someone is hittin the front end with a sledge!. No give whatsoever. Recently got a used Fatboy so I am not sure what does done to the front end in the past. Should I check the fork oil, change it, or could that even be the culprit. Is it possible someone used a lowering kit or something? Any suggestions would be very much appreciated
I recently lowered mine about 1-3/4" using a kit from Progressive, it's noticeably stiffer, although it seems to have gotten a little softer after putting on several hundred miles. I don't miss the stock nose dive when stopping but am not to keen on the new found harsh ride either. Somewhere in the middle would be better. I'll probably change the fork oil when I fix a leaking fork seal. I'll try a light oil, maybe that will help.
Fork oil doesn't compress, air does. More oil/less air = no compression. Less oil/more air = more compression. I experimented with lighter fluids and did like the feel of that. I've just installed the RICOR units in my Deuce, but haven't had a chance to run it much. What I've ridden so far feels real nice.
Here are couple pics, hopefully you can tell from these.
http://i760.photobucket.com/albums/x...y/IMG_0050.jpg
http://i760.photobucket.com/albums/x...y/IMG_0051.jpg
