Removing side markers / deuce
Old 04-22-2010, 01:19 PM
PBR2's Avatar
PBR2
PBR2 is offline
6th Gear
Question Removing side markers / deuce
I read a post earlier about removing the side markers off the front forks on a deuce would make it look a lot cleaner. Does anyone know how to remove them without screwing up the chrome?
Old 04-22-2010, 01:43 PM
jdsmitty10's Avatar
jdsmitty10
jdsmitty10 is offline
i would guess carefully pull them off. and then use goo gone to get rid of the leftover stuff... i thought about doing this to my deuce, just haven't gotten around to it yet.
Old 04-22-2010, 01:53 PM
twisted125's Avatar
twisted125
twisted125 is offline
hair dryer and fishing line. heat em a little bit, and slide the fishing line behind em. theyll come right off. +1 on the goo gone.
Old 04-22-2010, 02:14 PM
I8AGSXR's Avatar
I8AGSXR
I8AGSXR is offline
I pulled them off with my hands and didnt need the goo gone even tho I bought it.
Old 04-22-2010, 03:02 PM
Geoff's Avatar
Geoff
Geoff is offline
I loosened my reflectors with a heat gun and then removed them by hand. I used mineral spirits to remove the adhesive residue.
Old 04-22-2010, 06:09 PM
Mr Wasabi's Avatar
Mr Wasabi
Mr Wasabi is offline
WD-40 and fishing line.
Old 04-22-2010, 07:55 PM
snook592's Avatar
snook592
snook592 is offline
I just pulled 'em off and wiped it up with goof off
Old 04-22-2010, 10:51 PM
kiwideuce's Avatar
kiwideuce
kiwideuce is offline
they should come right off,maybe use a heat gun! a lot of guys say to remove reflectors!
Old 04-23-2010, 12:18 AM
deadduck357's Avatar
deadduck357
deadduck357 is offline
I just got one warm with hairdryer and used dental floss then to the other and did the same then used WD40. Same could be done with fishing line and GOO Gone.
Old 04-23-2010, 01:12 AM
micahpop's Avatar
micahpop
micahpop is offline
And how come you haven't heeded that advice?
Quick Reply: Removing side markers / deuce
