04 later softail speedo change
I was informed that if i change speedo on my Rocker (some aftermarket like Dakota, etc.), i need to purchase device which will allow to connect neew speedo. Otherwise the ECU will not accept it. They said all HD from 2004 must have it. I got recommendation for M-CAN adapter from Motogadget. Even i would not use any speedo at all, they told me i will need this device not to get ECU crazy.
Can you confirm or recommend other solution?
from my knowledge dakota has a harley specific line up that is direct fit plug n play.
http://www.dakotadigital.com/index.c...cat/cat515.htm
blackSP
04-05-2020 05:41 PM
