Calling all FatBoy Lo Owners
#9461
Thx
#9462
Sorry to hear about your troubles, I think that the oil cap problem may have to do with the oil tank or the crank case not venting properly. Did they do any work to the air cleaner? possibly clean or change the element, there are two hollow bolts that hold the backing plate to the rocker boxes that have two rubber tubes attached to them that vent the crank case pressure and if they are blocked it could cause crank case pressures to rise. Also the smaller line runing from the top of the oil tank to the area below the rear cylinder is for venting the oil tank, is it possible that it has become blocked or restricted. I would have to believe that this oil cap problem was "created" by some recent work to the motorcycle. As for your brake problem I'm at a loss. Please keep us updated about your progress geting these problems resolved. That's quite a kick in the *** to have paid dealer prices for service and then have trouble, but they are human too and can make mistakes. A good dealer will take care of you and do their best to get the problem resolved. If they come back and say you need a bunch of expensive work GET A SECOND OPINION, good luck and sorry to hear about your troubles.
#9464
Dark Lo
Wheels are 18x3.5 front, and 18x8.5 rear.
Fender came with Heartland 250 kit. You can also check this site out: https://russwernimont.3dcartstores.c...REET_p_49.html
Testament 27 - you are correct...it is a Memphis Shades fairing...nice taste!
Additional pic can be found here: https://www.hdforums.com/forum/membe...51-albums.html
Last edited by s5051; 04-30-2013 at 07:37 PM. Reason: Not sure why...format came out wierd
#9465
Dark Lo
#9467
Yes whole panel would have to be replaced. There are no bulbs to replace in the panel. The high beam indicator has power all the time and ground signal comes from switch to light up indicator. If you have power and ground to the indicator panel then the panel is bad. Fuses would be the first thing I would check.
#9469
Had UltraCool oil cooler installed today. Thought I'd post these as I didn't find any pics before I decided to get one. If I missed finding ones already posted... Well, it doesn't hurt to see more pics...
http://m1362.photobucket.com/albumvi...l?o=3&newest=1
http://m1362.photobucket.com/albumvi...l?o=2&newest=1
http://m1362.photobucket.com/albumvi...l?o=1&newest=1
http://m1362.photobucket.com/albumvi...l?o=0&newest=1
#9470
