Calling all FatBoy Lo Owners
#6911
I got the 1.5" tank lift from DK Customs. Started to install it on my 2012 Lo and found the hose from one side of the tank to the other keeps you from lifting the tank without replacing the line. They do supply a replacement line. Since I had a full tank of fuel and was a little skeptical about messing with the fuel line, I decided to save that for another day. Haven't done it since.
#6912
#6913
I did the 1.5" lift, it was very simple..there's a thread on here about how to fabricate your own out of some plates, but it gets complicated.. as far as handlebar clearance, if you don't have apes, you're going to be limited by how high you can go.. with the streetslammers i couldn't do more than 1.5" before the turn signals hit the tank. you can do more with apes, but also keep in mind that the higher you lift the front of the tank, the less fuel that the fuel pickup will be able to get, so you're cutting your range off.. i get about 175 to the tank now with the 1.5" lift
#6914
Other on hear really like their BasAss Lights taillights. Great product but certainly the most expensive.
#6915
#6916
it's because you're Canadian. jk. Yeah I had to take quite a few measurements before I realized I could only do the 1.5" lift, and even then I had to reorient my turn signals, and now I clear them by less than 1/5"..
On a side note, if anyone ever wonders.. if you're cleaning your rocker box covers (or anything really) and get a paste-like polish (like the Mother's Aluminum and Mag polish i use on the rocker boxes) on their black motor, don't fret.. go get a spray bottle of Simple Green concentrate, spray a bit on to a very soft towel, and scrub it off.. took the paste right off without damaging the black fins (that paste residue had been sitting on there since january too)
#6917
#6918
HD does not make a front signal relocation kit. I posted info on doing it 2 pages back on this thread.
#6919
They do make front turn signal relocation kits, just not for the Fat Boy Lo. At least they did 2 years ago, cause I put one on my Low Rider.
Checked out the D2Moto and the ExpensiveAssLights...I mean BrightAssLights. The D2Moto ones look good. http://www.d2moto.com/p-12438-harley...ake-light.aspx
#6920
http://www.customdynamics.com/street...taillights.htm
