Calling all FatBoy Lo Owners
Old 04-19-2011 | 12:11 AM
Caseyx's Avatar
Caseyx
Originally Posted by TattooBill
looking at apes for my lo, cancer in my arm only lets me go so high but it would be more comfortable with a rise. my ? is, what's intailed in installing 10 " apes on my 10 Lo?
Wire extensions, involves soldering usually. New cables...clutch, throttle and front brake. Fuel tank removal or at least shifted back quite a bit, i recommend removing it. New riser bushings recommended. As I was told, do it yourself, save a lot of dough and take your time to do it. Everyone here can help, I just finished mine yesterday.
  #2102
Old 04-19-2011 | 09:00 AM
Lawleywood's Avatar
Lawleywood
I still can't figure out why guys are taking the tank off to do the bars on a Lo. It is really unnecessary to go that route.
Riser bushings are probably not necessary on a 10" bar, but they are great and stiffen up the play when doing the apes. Do a +6 on your cables and you should be good to go.
  #2103
Old 04-19-2011 | 10:57 AM
beasleyiv's Avatar
beasleyiv
Originally Posted by Jim 2011 FB-LO
I remember seeing someone had powder coated one of the aux light bars on here and cant remember what page it was on and tried searching for it. I saw a freind of mine had the chrome one on her softail deluxe and really liked the look of it. I am looking at getting the heavier duty one and getting it powder coated, but wanted to see what was involved in the process...
That is me. The process I used was put the parts in a box and took them to the powder coater. Got the parts back and assembled. They did all the prep of the parts. I did disassemble the lights and such so all I took them was the metal parts.
  #2104
Old 04-19-2011 | 11:00 AM
Sgt_Jim's Avatar
Sgt_Jim
You really don't need to remove the tank, just disconnect it and slide it back a bit to get at the wire housings for the turn signals/etc that are under it
  #2105
Old 04-19-2011 | 11:09 AM
Mouth's Avatar
Mouth
I did mine all my self and yup I took the tank off. I used a Burly Brand extension kit. It worked pretty good. Just keep account of how tall your risers are too and It'll save you a lot of extra work. On the good side of that, at least you get to drink a few more till you finish.
Attached Thumbnails Calling all FatBoy Lo Owners-fatboy-lo-with-16-inch-carlini-design-flyin-apes.jpg
  #2106
Old 04-19-2011 | 01:04 PM
Lawleywood's Avatar
Lawleywood
I am with you Jim, I keep reading all these posts saying to take the tank off. That is just extra work that does not need to be done. Even the service manual doesn't say to remove the tank. If you undo the bolts and the console electrical connector and the quick disconnect, the tank pulls back plenty far to access all the connectors.
  #2107
Old 04-19-2011 | 08:43 PM
TattooBill's Avatar
TattooBill
Thanks guys, a lotta good info! I'll post pics when I getem on
  #2108
Old 04-19-2011 | 09:18 PM
MJ-13000's Avatar
MJ-13000
Thanks to each and every member on this thread!
Picking up the Lo on saturday!
You guys (and gals) created a monster! Well...I have detention tonight. I must write 100 times on the blackboard...
I will keep it stock,
I will....
...Hell..screw it all....where's Dr. Drew?..where's that catalog?...lmao)
Much thanks and respect to all. You all were and are an inspiration!
See ya out on the road!
To you
  #2109
Old 04-19-2011 | 10:05 PM
bigoil7's Avatar
bigoil7
Bout to do both of them myself. I've read that heat from a hair dryer and fishing line make removing reflectors easy.
Thanks Caseyx, blow dryer, dental floss, and and a little spray turtle wax was all I needed. Quick and easy. Pulled the fork reflectors off too while I was at it. That just required heat and muscle, had a black rubbery adhesive unlike the back reflectors. Unbelievable how much better she looks.
  #2110
Old 04-19-2011 | 11:33 PM
Seavonj's Avatar
Seavonj
4th Gear
Default Couple pics of my LO
Here are a couple of pics of my LO. Slowly doing the mods.
Attached Thumbnails Calling all FatBoy Lo Owners-photo-4-.jpg   Calling all FatBoy Lo Owners-photo-2-.jpg
