Calling all FatBoy Lo Owners
Old 04-04-2011, 02:51 PM
rrambo's Avatar
rrambo
rrambo is offline
She's plain right now.. but I've got big hopes and dreams for her!! V&H pipes, V02 or SE intake and haven't decided on EFI controller either...
  #1912
Old 04-04-2011, 03:04 PM
Caseyx's Avatar
Caseyx
Caseyx is offline
Originally Posted by beasleyiv
Ok, now that is funny. I feel ya, I just can't believe I didn't do that when I had mine apart.
****, I should take my forks apart while I am waiting on a few parts and send them to the PC'er...
I've read that it's dangerous...any truth to that?
  #1913
Old 04-04-2011, 03:08 PM
beasleyiv's Avatar
beasleyiv
beasleyiv is offline
Nope. Just have the bike up on a jack. If you have weight on them when you go to remove the top bolts, you'll get a surprise.
You have to remove:
Headlight
Tins behind headlight
wheel/brake/etc
Loosen pinch bolts, remove top cap bolts, pull them down and out of the trees. Disassemble on the bench.
  #1914
Old 04-04-2011, 03:40 PM
SkinnyonFatboyLo's Avatar
SkinnyonFatboyLo
SkinnyonFatboyLo is offline
Hey quick question.... I really like the street slammer bars, but don't really like the price. Does anybody know which version of the wild1 bars match the closest to the HD bars? As far as the rise and pullback? Also I know that most people say you only have to change the brake line with the HD bars, is that the same with the wild1 Bars? Thanks in advance for the help.
  #1915
Old 04-04-2011, 04:09 PM
Caseyx's Avatar
Caseyx
Caseyx is offline
You have to remove:
Headlight
wheel/brake/etc
Perfect! Already drained the brake fluid, in the middle of a bar swap now!
  #1916
Old 04-04-2011, 04:20 PM
Matt990724's Avatar
Matt990724
Matt990724 is offline
I just put 6.5in risers on my stock bars... the line that is the tightest is the throttle line... brake line is second.. have plenty of electrical wire/clutch cable.
But, the 6.5 risers fit... not sure what that means re: different bars, but wanted to throw that out there.
  #1917
Old 04-04-2011, 04:24 PM
BigRedFan74's Avatar
BigRedFan74
BigRedFan74 is offline
Hey Nuts, I bought a layback and if you read the instructions it says "remove oem frame and discard". Laughing mao the whole time I was doing it, I slowly bent the orignal bracket to make room for removal - and of course- "discarded"
  #1918
Old 04-04-2011, 05:15 PM
Sgt_Jim's Avatar
Sgt_Jim
Sgt_Jim is offline
Input from the diddler.. if you look back a few pages I wrote a quick blurb on how to get the lowers off of the actual forks.. it's incredibly easy, and like a 5 step process:
..assuming you have the forks out of the housing..
1) Remove the drain screw from the back of the fork on the lower ends
2) Turn the fork upside-down, and look in the bottom. You'll notice a brass colored Allen-headed bolt sticking in the bottom of the fork. This holds the actually spring assembly to the lower fork. Remove these bolts.
3) Look in the top of the lower, there is a retension spring sitting there..it pops right out with a small screw driver, remove these and set them aside.
4) Put the end of the fork on a padded surface (a folded rag works) so that it is facing upright.. get a friend to hold the lowers with a downward force (try to keep the bottom planted on the ground)
5) You need to press downwards on the fork, then slam it upwards as hard as you can.. this will get the rubber ring inside to pop loose out of the lower..then the spring assembly will slide right out. Replace these rings, they're about $10 from Harley each, and idk the part number off the top of my head. And that's it!
...of course reassembly is much different..still relatively easy..
yeah.
  #1919
Old 04-04-2011, 06:06 PM
JIMSFBL's Avatar
JIMSFBL
JIMSFBL is offline
Originally Posted by Arv
@ Willie & Jimsfbl
Your front fenders are very nice indeed, from where?
Also i see you got it lowered, that ride is just about perfect, what did you do bro?
I bought mine off of ebay for $106 shipped. It was raw tin, so I did all the sanding, priming and painting myself.
As far as lowering it, I have the shotgun shock (air ride).
Here are some pics to show the new fender next to the old for comparison on the paint matching the stock fender.
Thanks also for the comps! I'm sure Willie feels the same.
I know the glare is bad, because I suk at taking pics hehe.
  #1920
Old 04-04-2011, 07:35 PM
FBLJosh's Avatar
FBLJosh
FBLJosh is offline
Did you have to modify the fender in any way? I like this mod and might do it if I can find a fender for the price you did!!
Quick Reply: Calling all FatBoy Lo Owners
