Calling all FatBoy Lo Owners
#1551
also got the new digital speed/analog tach and flush mount caps installed a few days ago
#1553
#1554
Might want to pull off that upper fork clamp and have it powdercoated black as well! Check out mine. I even did the fork tube caps and washers as well as the handlebar washers since I didn't like that gleaming circle of metal eyeballing me from under my new street slammers heh heh.
By the way... most decent powdercoating operations will be able to get the HD brand black wrinkle powder for things like your primary, transmission side cover, cam cover, uppern and lower rocker boxes and such.
FYI: The stock clutch cable is workable with street slammers, but it is LONG with them. Earlier someone posted a HD cable chart, but HD has updated it recently to reflect diamond black clutch cable 38941-09A instead of the 38877-blah blah blah that was in the chart earlier on the forum. When I first pulled the cable out of the bag I thought it would be short, but it fit just right. It parallells the cross bar and the stem perfectly.
#1556
Good thing I have a garage or mine would be in the house for winter mods also and that could wiegh heavy on the marriage thing.
kick some *** on those mods jim!
#1558
Thanks man.. It's really funny when the tax assessor came in, or the public server guy comes in to read the gas meter and goes "um. Yeah. Bachelor pad, huh?"
Anyways.. for those of you that got your forks powder coated, did you guys have to disassemble the entire fork? i'm really trying to avoid doing that..i already drained the fluid and all that, but it really looks as if i could leave the springs and everything in, and they'll just tape off the part that doesn't need to be coated.. at least, that's what they did with my dad's brake rotors on his nighttrain, they actually taped off the part that the brake pad hits and did an almost perfect circle on the inside..looks pretty sharp.
#1559
1. The forks do need to be fully disassembled. Powdercoating bakes the paint on at 400ish degrees. Your fork seals cant take that. Any powdercoater worth their salt will also tell you that the devil is in the prep work when it comes to powdercoating. They should go through an extensive cleaning/degreasing process before they get painted. One drop of fork oil seeps out onto where it gets sprayed, and it will bubble/crack off.
2. You can't do this yourself. Please take that to heart. In gutting my bike, the forks were the only thing that I took into the dealership to have done. The fork springs are pre-loaded and if you try to pull the tube plugs out you will find a fork tube plug sized hole in your dining room ceiling (or your skull). The rebuild kit costs like $25 and to have them disassembled and reassembled cost me $50. Even IF you can find a way to safely shoot the plug into a mattress or something, compressing the spring to install the fork tube plug without stripping the threads takes 2 people + special tool part # 19879834IJFHE if ya catch my drift. Let THEM do it, that way if they jack it up THEY have to replace it
#1560
