Calling all FatBoy Lo Owners
#1531
Alright... my Lo is done after 3 months of overhauling (pictures to come when it gets daylight). I have a problem though. If I have the run switch on, as soon as I turn the ignition switch to "on" the motorcycle tries to start itself. I am hoping someone else had the same thing happen and it is a simple "Oh you plugged the ignition switch plug in backwards". I REALLY don't want to have to pull the tank again to check to see if I wired all of the plugs behind it correctly or pull the right switch assembly again. FYI I did go with the street slammers and rewired the plugs instead of cutting and soldering. Is there a brainfart quick "Oh i had that happen before" out there?
Hey Lo Brothers,
Just returned from a test run,testing my new lighting...HD LED headlight,custom dynamics turn signals,Brightass light,tail light(bal-3st) and some accent lighting....looked like a billboard on Las vegas strip!!!!Head light....WOW!!! LIKE THE SUNS OVER YOUR SHOULDER...turn signals...GREAT!! very bright! Tail light...Very Bright...highly recommend!!...RECOMMEND ALL OF THIS LIGHTING...post some pics when i figure out photobucket....just would like to thank you LO FREAKS!!! (LIKE MYSELF)...daveflstfb,jimfbl,rquirch..ect....got one question(a stupid one)what do you freaks use to clean your satin chrome ,brush aluminum ....motor covers... was at a dealer today....a dealer that sucks!!! and asked that question ,and they looked at me like i was retarded...maybe right but should have answered my ?...RQUIRCH,,,,where did you get them heat shields!!!! Thanks freaks
i'm drooling over the LED headlamp...
The heatshields are the standards ones that shipped with the pipe, i took them off and drilled trough with a stepping bit.
#1532
#1533
Hey Lo Brothers,
#1536
holy crap!!! i dont know about this and it hasnt happened to me but i would guess that you crossed some wire somewhere and voltage is being applied to the starter switch circuit when you apply voltage to the "run" circuit by flipping the switch. if i was you i would open that housing and put a meter on the start switch hot wire and a gorund and flip the "run" switch, if you see voltage that might be the problem..
#1538
