Calling all FatBoy Lo Owners
How about these for highway pegs that attach to front floorboards?
http://www.kuryakyn.com/products/539...e-arm-mark-iii
or as previously noted by sbarron,
https://www.aeromachmfg.com/Aeromach..._Pegs_s/42.htm
Throttle control device - Klever Lever
This is what I use for throttle control. Works fairly well, cheap and innocuous. Also available on ebay and other places. Comes chrome finish or black.
https://www.google.com/search?q=klev...38473639336437
The Klever Lever works fine and for under ten bucks and no real modification, what have you to lose by trying it? I do not use it for extended periods, only to give my hand/wrist a short break on long rides. Yes, if installed as directed, these simple devices lock the throttle. However, unlike electronic cruise control, unless you're in the middle of Iowa or somewhere the ground is really flat, you'll soon other be losing or gaining elevation and you'll want to take back control of the throttle to maintain speed. It's no replacement for electronic cruise control, that's for sure.
yeah,because with road conditions it will tend to move a bit and you'll have to make adjustment.. but they work good enough to get that cramp out.. i don't get much cramping, i use smaller grips. Kuryakyn has those big rubbery ones that take a lot to get your hand around.you're not holding onto something that bigger than your palm for to long. i use these.
http://www.ebay.com/itm/Arlen-Ness-B...NYa~gb&vxp=mtr
The Klever Lever does not replace the existing wheel, it fits right over it.
