Softail Baggers Only...Pics please
#202
#204
Nice! I like how the bags fit close to the fender without filler strip, are a couple inches taller and a lot wider then FL bags. Any side pics of the bike. Both sides?
#205
Here are some side pics....
#206
Received 24,094 Likes
The bags are mounted using the original mounting brackets from the leather bags so there is the same space between the bags and the chrome mount on the fender. Very slick.... Capacity is about 32 litres and are larger, I believe, than FL bags. I quite like and there doesn't seem to be anything like this out there.
Was it difficult to get the mounting brackets off the stock bags, and to mount them on the new bags? Also, it appears there was no conflict with the Heritage saddlebag guards, is that right?
boz12 (12-31-2016)
#207
#208
I think your bags are the nicest hard bags I've seen yet for the Heritage, and the price seems right. Are you completely happy with the quality overall?
To remove the mounting brackets off the stock I just needed to drill out the rivets and rivet the brackets onto the hard bags. Less than an hour to install start to finish. They lock, my half helmet jacket, and gear all fit neatly on one side and my other gear in the other. I use the FL bag liners for road trips to take my gear with me. No conflict with the saddlebag guards at all. I am actually trying to locate the saddlebag guard lowers, similar to touring models, but Harley doesn't make them for the softail. I may be able to get them from the company that did the engine guard covers.
Thanks.......
#209
#210
You can get the FL style bags in fiberglass or ABS, extended or not. There are many options out there and many companies that make the HD FL style bags. There are also many other bags that companies have come up with their own design. All work and all are good for the most part, just depends on what you want.
