I've seen some great looking softails on this thread, specifically the ones with Samson True Duals. I have Samson True Duals as well on my Deluxe, but without baffles and use the Thundermax for the fuel management. I still get some decel pop and am trying to tune it to no decel pop (if possible). Does anyone have the same problem and if so, how did you fix it? And what fuel management do you use? Thanks,
Matt
it sounds to us at Samson you may need just a slight more fuel to eliminate the popping on decel.
thank you,
JR
Santo who did you get your front rim? And what brand of tire are you using?
The wheel cam from drag spacialtys im not sure of the brand it is 2.5 wide, the front tire is a 90/90 metzler. Some say that you can mount a 21" wheel off an night train, it should be a direct swap as long as you have the right axle size. The best you grade you can do to a Deluxe.
SD Nick: I am not a bagger lover but I must say, that is the coolest Deluxe I have ever seen. Very nice job man! I love it! I live in Brandon, SD, btw, not too far from Madison, SD. Congrats on your awesome bike.
