Softail Baggers Only...Pics please
Old 05-13-2020, 04:34 AM
2013fatglide's Avatar
2013fatglide
2013fatglide is offline
Default Bad dad fender with aftermarket brackets no good
So when I mounted up the bad dad fender above I noticed an issue.. the fender is great nothing wrong with that at all.... But aftermarket brackets make the stretched saddlebags sit 2 or 3 inches back too far past the fender.. I was trying to avoid buying the bad dad brackets because they are 410$. But when I looked you can see the bad dad brackets make the bags sit farther forward to be flush with fender. Here are pics. The 1st set of brackets are the one I have 2nd set is bad dad
  #1402
Old 05-13-2020, 04:51 PM
2013fatglide
Ok so for whoever is interested.. I contacted John at bad dad and he told me that his brackets amdaand fenders are designed for 2013 and below saddlebags.. so he said his brackets make the boxes sit toward the front of the bike more than your regular bagger conversion bracket's about an inch closer. So I had to buy the brackets to make my 14+ bags look decent with the fender. Brackets are almost ,400$
  #1403
Old 05-13-2020, 11:50 PM
BikerPepe`'s Avatar
BikerPepe`
BikerPepe` is offline
Received 3,939 Likes on 1,369 Posts
Dang. Seen you comin' huh? Makes me appreciate my pre-kits, custom setup.
  #1404
Old 05-14-2020, 12:20 AM
dmonger's Avatar
dmonger
dmonger is offline
Here is a couple pictures of my work in progress bagger.
BikerPepe` (05-14-2020)
  #1405
Old 05-14-2020, 04:00 AM
2013fatglide
Dmonger what fairing is that ?
  #1406
Old 05-14-2020, 05:14 AM
dmonger's Avatar
dmonger
dmonger is offline
Reckless knock off. I don't know the actual manufacturer. I bought it off another user on the forums.
  #1407
Old 05-14-2020, 01:59 PM
Flanman55's Avatar
Flanman55
Flanman55 is offline
Monger, how did you mount that?
  #1408
Old 05-14-2020, 02:03 PM
dmonger's Avatar
dmonger
dmonger is offline
I'll pull it off and take a picture later. But the bolts that hold the nacelle are running through rubber grommets and the fairing attached to them.
  #1409
Old 05-14-2020, 02:04 PM
2013fatglide
My reckless attached to the windshield mounting holes on the sides if interested
  #1410
Old 05-14-2020, 04:39 PM
Flanman55's Avatar
Flanman55
Thanks Glide
Quick Reply: Softail Baggers Only...Pics please
