Deluxe - Layback Plate Frame
Old 04-01-2010, 08:02 AM
luvtoride's Avatar
luvtoride
luvtoride is offline
It's a job I'd like to do unfortunately my softbrake relocation kit has been backordered for over a month now. Anybody know of a relocation kit that puts the plate under the taillight besides Softbrakes?
Old 04-01-2010, 08:07 AM
dansax's Avatar
dansax
dansax is offline
I just reached under the fender with a small ratchet and installed it on my FatBoy Lo. Then I ruffed up the chrome frame and sprayed it flat black, looks factory.
Old 04-01-2010, 10:23 AM
OS_DELUXE's Avatar
OS_DELUXE
OS_DELUXE is offline
Use the Z-bracket. If you don't you run the risk of it breaking where it attaches to the tail light... I didn't use the Z-bracket and it broke.
Originally Posted by plutnicki
Anyone not use that Z-bracket putting it back on? Seems like overkill to have to support it at the top (same with the current setup, IMHO)...
Thanks!
Old 04-01-2010, 10:28 AM
Drummerboy301's Avatar
Drummerboy301
Drummerboy301 is offline
I had ordered the softbrake housing, relocator and led frame from softbrake and also had been told that they were backordered. Call JP cycles, they have everything in stock and just about the exact same price.....
Old 04-01-2010, 10:41 AM
plutnicki's Avatar
plutnicki
plutnicki is offline
Yeah, I used the Z-bracket. Wouldn't have been worth it to not to anyway.
Old 04-25-2010, 05:47 AM
SoftailDan's Avatar
SoftailDan
SoftailDan is offline
Stage I
Default Layback plate bracket
I bought mine and my wifes from BadAssChrome.com. The directions are easy; first remove plastic cover from back of tombstone tail light then be carefull not let the two thru bolts that hold the bracket from falling out......, a pain to retrieve then simply put some temporary duct-tape on the heads from under the fender, reassemble and your done. All done without removing the fender or rear wheel.
sanlyn
01-23-2021 07:53 PM
cskyler22
02-27-2008 03:48 PM
earl b
02-01-2008 04:39 PM
edeluxe07
01-22-2008 02:08 PM
Bluedog20
09-24-2007 03:52 PM
Quick Reply: Deluxe - Layback Plate Frame
