Does anyone change there own tires
Old 03-30-2010, 03:25 PM
Fatboy Brian's Avatar
Fatboy Brian
Fatboy Brian is offline
Default Does anyone change there own tires
I do almost all my wrenching myself. I've watched some guys change and balance there own tires on youtube. I always changed my own tires on my motocross bikes. I've thought about ordering the stuff to do the balancing. I already have tire irons. Any thoughts or suggestions would be helpful.
Old 03-30-2010, 03:27 PM
DR. V-TWIN's Avatar
DR. V-TWIN
DR. V-TWIN is offline
Former Sponsor
Check out the No mar or the cycle hill tire changer.
Old 03-30-2010, 03:28 PM
DaddyKnuck's Avatar
DaddyKnuck
DaddyKnuck is offline
Received 1,664 Likes on 946 Posts
I change all my own tires. Saves a lot of money and you know the job is done right. I use the Harbor Freight changer (just the bottom), some ATV tire irons (or tractor if you have them) and I balance with Dyna Beads or air-soft pellets. Piece of cake. But I'm only 61. If you're a lot older you may want to get an automatic machine. LOL!
Old 03-30-2010, 08:54 PM
kc5gxc's Avatar
kc5gxc
kc5gxc is offline
I change mine. Use a clamp type bead breaker, homemade tire irons and dyna beads to balance...but I'm only 65. Older, maybe you could use one of them Harbor Freight machines to help with the work. It is a little strenous on the old bod...ha ha.
Good luck..........Pete
Old 03-30-2010, 10:22 PM
oct1949's Avatar
oct1949
oct1949 is offline
I did yrs ago and pinched holes in the tubes, never again, $50 bucks to have someone install and balance them is well worth it to me..
Old 03-31-2010, 12:29 AM
SoftailSlim's Avatar
SoftailSlim
SoftailSlim is offline
Tires are easy, just don't pinch the tube...
Old 04-01-2010, 06:20 PM
kiwideuce's Avatar
kiwideuce
kiwideuce is offline
i used to do it on my dirt bikes! havent on my scoot!!
Old 04-01-2010, 07:34 PM
Dorkman's Avatar
Dorkman
Dorkman is offline
Used to do it on dirt bikes and road bikes with spoke rims and a tube. Not worth it to mess with alloy rims and tubeless, in my opinion. Take 'em off the bike and let someone else do it for $20.
Old 04-01-2010, 08:38 PM
CSRflstc's Avatar
CSRflstc
CSRflstc is offline
I do my own and saved $140 bux. Dealer price of tire and install was just over $300. I bought a signature series Dunlop and tube for $160 and paid myself the $140 labor! That buys a lot of beer and smokes!!!!
Old 04-01-2010, 11:07 PM
sancho_panza's Avatar
sancho_panza
sancho_panza is offline
Yes, I made a long post about this a short while ago. Cruiser tires are much stiffer than motocross or sportbike tires, so it takes more muscle. I just use spoons, 2"x4"s, empty capri sun pouches (as rim protectors), and lots of lube. Balancing with weights (the way every OEM of every motor vehicle does) is ridiculously easy with a straight rod, some cheap bearings, and a couple cinder blocks. [I did use one No Mar tire spoon with its built-in polyethylene rim protector. It was awesome and provided extra protection to my powder-coated wheels.]
Quick Reply: Does anyone change there own tires
