opinions on cam upgrade for '02 tc88
i have my '02 fxst torn down right now to replace the cam chain tensioners.i figured i may as well get some performance increase while i'm in there.i've done some searching & am still unsure of which cam to go with.i'd like to use a cam that is a simple drop in replacement & allows using the oem pushrods if possible.other motor mods are hd carb kit(forget which one), hpercharger air cleaner & open exhaust.any and all input appreciated
Put Andrews 21 in my 88". Others install the 26 and SE 203's. All these will bolt in and use stock push rods. imo - since you have it all apart, well worth installing cams. Also, an open exhaust hurts low to mid tq. Changed to a 2n1 last fall and this was also a noticeable improvement.
Be sure to change out the inner cam bearings to b-148. Only costs about $15 for both.
thanks for the info.how do you like the andrews 21 cams? was there a noticable increase in performance? if so, where do you notice it?of the 3 you mentioned, how do the se 203 cams compare? reason i ask is i see a set for sale right now at what looks like a good price.to clarify, i'm running v&h straightshots with no baffles & torque cones.i've read about the torrington b-148 inner cam bearings - can anyone tell me where i can buy them.thanks again
Got my b148's at the dealer, they stock them. They are also sold on eBay.
i installed the Andrews H55 cams along with SE adjustable pushrods and an S&S gear drive kit. my big *** adds about 200 pounds unsprung weight and before these upgrades performance was sluggish at best. now, i have no trouble keeping pace with others. these upgrades on a 2-wheeler would be outstanding. good luck with whatever you decide.
grimm
grimm
thanks, i appreciate itok, so the 203's are out then...i haven't even thought about fuel economy. currently getting 44/42 mpg consistantly. not concerned if i lose a few mpg's.the 26's seem like a good choice from what i've been reading.i planned on keeping them chain drive. am i correct in assuming the 26a is the chain drive equivalent of the 26g.
that's good to know. i know i was limited on choices, but had no idea how far i could go. did you check valve to piston clearnace, etc. as recommended, or are they pretty much safe to install? this is my 1st time in this kind of motor and i'm looking to keep it as simple as possible...simply put, i don't want to get in over my head lol do you know if they will work with the stock pushrods? thanks for the replies. i'm looking into all suggested.
