My winter project starting late - 200 on my 02 NT
#41
#43
I was able to find a belt this weekend at Al Muth's Harley Davidson in Black River Falls.
I started assembling this weekend and tonight. Now I need a rotor spacer. The belt as it sits is rubbing on the tire. Its currently on a stand so I dont even want to see how it is when the tire is on the ground with the weight of the bike and a rider.
#45
get the vulcan kit spacer, about $40, that will move belt away from the tyre enough
http://vulcanworks.net/Pulley-Spacer...0-p-1-c-2.html
http://vulcanworks.net/Deuce-180mm-W...Kit-p-392.html
dont no,maybe one of these may help
#46
#48
Ended up buying a Drag Specialties .0475 in. Rotor Spacer. Had to modify it a little by grinding out the bolt holes and the center hole. Spacing for the belt seems to be good now.
We welded on the other frame horn last night. Put the wheel on to see how it all fit and everything looks good. It is finally sitting on the garage floor supported by itself. Need to drill out the holes in the horns yet, then it should be good to go.
