Ape hangar cable help!
I just put 16" apes on mine and used Sterling II Chromite from Magnum Shielding. I used the following lengths:
52" Brake Line, you may want to go 54" (mine was barely long enough)
39-40" Throttle/Idle Cables
74" Clutch Cable
The brake line is the only one I was close on, the other fit great and would work for 17" apes, unless they are funky shaped or something.
74" Clutch Cable
