Tire Inner Tube for 150/80x16
Need a rear tire and also want to replace the tube. The two places where I would like to purchase the tire do not have the exact tube for my tire - 150/80x16. I read that you can go either larger or smaller in tube size be 15mm's. So a 140/80x16 would work on my 150/80x16 tire? But, the rim size must stay the same. The stealer wants $25 for a tube!! Also, do you guys install heavy duty or standard tubes?
Good question! Not 100% sure. Bought the bike used with the rims already installed. The valve stem only has a nut, no rubber washer - so Im guessin its tubed?
Mines not tubeless and yes that tube will work. You can use the heavy tubes if you want but I just change mine to new every other tire. If a nails going to get you it won't matter much to it whether or not you have heavy tubes. And my brother-in-law has tubes in his with the smooth rims also.
Holllllly chit,,,, Ur worrrrrried bout saving 10 bucks on a tube that may save U from having a blow out....... just don't understand...... I had new rubber put on and the INDY said the tubes don't need replaced every time,,, every other time.....so it cut the price to $12.50 a change.....
Just asked what size will work cause they do not have the exact tire size for the tube, and what type tube guys are using.
Now we know U too seem to care about "saving" $12.50 and change every other... umm... jk
Thanks for contributing
