Opinions on Rivera Primo headlight
How well does the light work? I have a cobra II and that light is great. What about signal visibility? Are they easy to see right next to the light? Do they stay on as running lights?
as far as being right next to the light you cant see the blinkers...and harder to see in the daylight (sun) unless your looking staight at em.....the headlight is better (brighter) then stock.......you can run them as running also but you will need a load eq, i was told if you just use them as blinkers you dont ,and i have had no probs with just the blinkers and i have leds in the rear also with no eq
TravelingTall
08-16-2019 08:54 AM
beary
06-26-2017 02:51 PM
