Custom front brake line: Banjo fittings and routing question.
I'm measuring to have a custom front brake line made up and had a couple questions...
First... I'm running 14" apes. How do you folks route the line from the master down to the caliper?
Next... It seems that the line would "flow better" with the shape of the bars (Fly'in Apes) if I were to have a 90* banjo at the master, then curve the line down to the top triple. From there go straight down to beneath the lower triple to the clamp there. Then curve it down to the caliper. Are there any possible issues with going with the 90* at the master as opposed to the straight one?
Yep... that's what I have now... By the looks of it, your bars may be a bit narrower than the Carlini's I have. And the brake line seems to almost right next to the "vertical" section of the bar. That's the fitting I'm thinking of replacing with one bent at 90*.
If you look at your sig picture, look at the way the clutch cable bends/sweeps coming out of the lever/perch assembly. In my mock-up, using a HD stainless brake line from a NT, I was able to almost duplicate that same sweep and curve found in the clutch cable but with the brake line! It looked very well balanced!! The exception was the throttle/idle cable which made that side look a bit "bulky", but (IMHO) much better than stock.
Either way, straight or 90*, I'll be needing a 54" cable. Maybe a quick call to Magnum Shielding is in my future!!
![Icon Wink](https://www.hdforums.com/forum/images/smilies/icon_wink.gif)
![Icon Beerchug](https://www.hdforums.com/forum/images/smilies/icon_beerchug.gif)
Does you front brake cable have a 90* banjo fitting?
Thanks
Did you ever go for the 90* fitting? If so, how did it work for you?
Thanks
Yep... Went with the 90* fitting and it worked as expected. Be advised... Some 90's are longer than others. The one on my Magnum Shielding lines is quite short. About 2" front the mounting surface of the master to the start of the line.
