roland sands seat kit and a little bit of welding
Old 02-13-2010 | 02:44 PM
yep's Avatar
yep
Account Suspended
Default roland sands seat kit and a little bit of welding
I had a customer send me this seat and I just have a few problems with it .. first off this is a roland sands seat kit ... first problem I have with this seat ... it has three bolts that hold the top section of this pan in place .. now tell me if you cover the upper part of the seat pan how do you get a allen key on the bolt to hold it so you can screw the nut on ... also the upper bolt is coned and sits flush in the pan , but the lower pan is not coned. this causes the upper pan to sit about 1/4 inch up off the lower , so the two pans do not bolt flush to each other .. my next problem is the upper pan is made out of like 16 or 18 GA steel .. this gives posts one problem with me is now I have to finish the edges with some round stock so it doesnt cut thru the leather ...
I know this sounds like a ton of B#$%ing .. but really as much as they get for these pans you think you would get a little better built product ... it looks like they had a homeless guy cut the upper shell for the pan ..on a good note , the lower pan is laser cut and looks really clean ... I just figured for the cost of the seat pan it would be a little nicer ...
ok here are the pics of my welded bolts and the seat ...
Old 02-13-2010 | 02:45 PM
yep's Avatar
yep
Account Suspended
Old 02-13-2010 | 02:46 PM
yep's Avatar
yep
Account Suspended
Old 02-13-2010 | 02:47 PM
yep's Avatar
yep
Account Suspended
yep's Avatar
yep
Account Suspended
<embed width="600" height="361" type="application/x-shockwave-flash" allowFullscreen="true" allowNetworking="all" wmode="transparent" src="http://static.photobucket.com/player...m/SANY0775.flv">
Old 02-13-2010 | 04:41 PM
Tom84FXST's Avatar
Tom84FXST
Nice TIG work
Old 02-13-2010 | 05:00 PM
skipper469's Avatar
skipper469
At least you know what your doing! Others less skilled might end up having an "oh sheet" kind of moment.
Old 02-13-2010 | 05:06 PM
m i k e's Avatar
m i k e
for the cash you'd exspect more well made product
Old 02-13-2010 | 05:25 PM
miami's Avatar
miami
That is some nice welding
Old 02-13-2010 | 05:58 PM
yep's Avatar
yep
Account Suspended
that is what I am saying ... I mean they get bank for there product and there is really no planning that went into the seat ..
and thanks for the welding comment ... been TIG welding for a few years now so I hope I can lay down a bead
Quick Reply: roland sands seat kit and a little bit of welding
