Clicking Sound(?)
Old 02-10-2010, 04:15 PM
PPBART's Avatar
PPBART
PPBART is offline
Default Clicking Sound(?)
I decided to change out the battery on my '05 Deluxe -- no issues with the original yet, but I'm planning on an extended road trip this spring and a 5-yr old battery is just another preventable problem.
I bought a replacement from the local HD dealer yesterday and decided to do the swap this afternoon. No problems getting the old battery disconnected -- negative side first, then positive -- and removed. I set the new battery in place, connected the positive cable and then started screwing in the bolt on the negative terminal. I thought I heard a low clicking sound, stopped immediately and verified the ignition switch was OFF. I resumed tightening the negative connection and again was sure I heard a clicking sound for just a few seconds, then it stopped. I finished the installation, then turned the ignition switch on -- lights on as expected. Turned kill switch on, engine logo on speedo appeared as usual, faded as usual, and bike cranked/started right up. I shut the bike down, then rechecked everything before reinstalling seat. I cranked the bike again and went for ride, everything normal.
Maybe I was hearing something that wasn't there? If not, what could have generated that clicking sound?
Old 02-10-2010, 06:10 PM
keno's Avatar
keno
keno is offline
Might have been the fuel pump?
Old 02-10-2010, 06:29 PM
PPBART's Avatar
PPBART
PPBART is offline
But the ignition switch was verified as off...
Old 02-10-2010, 06:46 PM
IronAss's Avatar
IronAss
IronAss is offline
Received 12,240 Likes on 4,779 Posts
All this electronic **** they got in em nowadays who knows? I'm thinkin maybe a relay for the security system or something like that. I've heard it as well when reconnecting the battery on my 05. I wouldn't worry about it.
Old 02-10-2010, 06:50 PM
xraybox's Avatar
xraybox
xraybox is offline
That would be my guess.
Old 02-10-2010, 07:52 PM
DR. V-TWIN's Avatar
DR. V-TWIN
DR. V-TWIN is offline
Former Sponsor
That is the relay. It's all good.
Old 02-10-2010, 08:12 PM
DaddyKnuck's Avatar
DaddyKnuck
DaddyKnuck is offline
Received 1,664 Likes on 946 Posts
Relay. Nothing to worry about.
Old 02-10-2010, 11:17 PM
Gray_Drifter's Avatar
Gray_Drifter
Gray_Drifter is offline
I hear that same sound on my 2004 Fatboy every time I disconnect or reconnect the ground cable on the battery. It's exactly the same sound I hear when I twist the dash **** to the ignition position. I've been told that it's normal and not a problem.
Old 02-11-2010, 07:00 AM
PPBART's Avatar
PPBART
PPBART is offline
OK, at least I wasn't just hearing things...
Thanks for the info!
Old 02-11-2010, 09:30 AM
tk353's Avatar
tk353
tk353 is offline
initialization of the ecm causing the relays to click. like a sys check
Quick Reply: Clicking Sound(?)
