good evening all. i have the 2006 nightrain project. my bike is fuel injected. is the fuel pump from a 2007 fxst the same as my 2006 nightrain? i think i found a tank set. please let me know. thankyou
I beleive you should be ok, I changed my tank from an 07 Deluxe and put a tank on from
an 05 softail standard and had no problems. I think in 08 H.D. changed the way the
float and fuel pump install in the tank.
hope this helps
My 2006 softail parts catalog shows the Fuel Pump assembly as part #
62897-01B for 2006 Softails. Now this is the complete kit,which means you get a housing,cusionrubber sleeve,endcap,cablestrap,pump. If someone can now post you some stats from a 2007 catalog we are set.
