Starting bike w/clutch in
Old 02-09-2010, 06:54 PM
Chicago Bob's Avatar
Chicago Bob
Chicago Bob is offline
Location: Illinois - Our governor MAKES our license plates!
Clarification. Never jerks forward when in neutral, just in first gear.
Old 02-09-2010, 07:01 PM
JustDave71's Avatar
JustDave71
JustDave71 is offline
yeah, you say it's a "fairly good" grab forward when starting in first. That's not right.
Old 02-09-2010, 07:42 PM
snip0721's Avatar
snip0721
snip0721 is offline
sounds like the clutch was improperly adjusted, then compensated for with the cable adjustment. full pull that clutch should be totally disengauged, other than the normal fluid sticking and cold temps. steve
Old 02-09-2010, 08:09 PM
2wheeltom77's Avatar
2wheeltom77
2wheeltom77 is offline
I always start mine in neutral unless I want to simulate an evo idle. I've actually been in a couple "old guys laughing at the new harley" situation trying to start in first with the clutch in. Sometimes it coughes out the intake and dies. Sometimes it seems to start fine in first. Been like that since it was new and never been adjusted in 15K miles. I've tightened the cable and that's all.
Old 02-09-2010, 08:16 PM
Craig4711a's Avatar
Craig4711a
Craig4711a is offline
That happens because you have a wet clutch. My 09 Road Glide does the same thing. I always put it in neutral before starting. I also noticed, when it's warmed up a bit, if you pull in the clutch and wait about 5 to 8 seconds before you shift into first gear, you lose that first gear clunk. Just my experience......
Old 02-09-2010, 08:21 PM
SD Night Train's Avatar
SD Night Train
SD Night Train is offline
you're never supposed to park your bike in gear
Old 02-09-2010, 09:20 PM
jimmers1817's Avatar
jimmers1817
jimmers1817 is offline
Guess you're a flatlander, huh? Me too but when I got into mountain country I learned you never park your bike in neutral.
Old 02-09-2010, 09:57 PM
Tao3535's Avatar
Tao3535
Tao3535 is offline
Read somewhere (service manual?) that you should put it in neutral before turning it off because Harley doesn't recommend you start it in gear. Reason being that the clutch plates still have some friction even with the lever pulled back. Either due to the cold or due to precise measurements of today's parts? I don't know, anybody else read something like that?
..I'd leave it in gear too if I parked on a hill..
Old 02-09-2010, 10:00 PM
Doug S's Avatar
Doug S
Doug S is offline
What's wrong with leaving it in gear?
I've been doing it wrong for along time I guess...
Doug
Old 02-19-2010, 01:54 PM
pjmoraldo's Avatar
pjmoraldo
pjmoraldo is offline
HOW DO YOU KNOW?
Originally Posted by Dustmaker
As stated above, clutch cable just needs to be re-adjusted. You need to let them know where you wish for your clutch to engage. No big deal really.
I always start my bike with the clutch pulled in.....the first time you go to start your bike in gear, with out the clutch engaged, with a ton of friends standing around, and bike jumps forwardand hits the bike in front of you....no more to say, and don't ask how I know
Quick Reply: Starting bike w/clutch in
