what tools to bleed brakes ?
Old 02-03-2010, 11:04 PM
ScReaMnEagLE22's Avatar
ScReaMnEagLE22
ScReaMnEagLE22 is offline
Default what tools to bleed brakes ?
Are there any particular tools or tips you guys use to bleed your brakes ? Im thinking of getting one of those pumps to push the fluid back up through the line and push the bubbles out through the reservoir instead of the pumping the brakes method..
Old 02-03-2010, 11:23 PM
DyNaBoB's Avatar
DyNaBoB
DyNaBoB is offline
give me a pm and i will give ya my #.........i have some tips for ya you wont need any tools...........
Old 02-04-2010, 05:16 AM
dynhd1's Avatar
dynhd1
dynhd1 is offline
Google speed bleeders, will make the job easier they are bleeders with a check valve in them .
Old 02-04-2010, 06:37 AM
Nickrc3's Avatar
Nickrc3
Nickrc3 is offline
Not necessary, but a Mity-Vac pump. http://www.mityvac.com/pages/products_hvpo.asp
Best $45.00 I've spent and makes the bleeding process foolproof.
Old 02-04-2010, 07:51 AM
RockyTopRider's Avatar
RockyTopRider
RockyTopRider is offline
speed bleeders or two people
Old 02-04-2010, 08:52 AM
twisted125's Avatar
twisted125
twisted125 is offline
didnt use that fancy stuff, Dyna Bob gave me a crash course in making it simple. Surprised the hell out of me how easy it was. Ive got nice positive brake now. 2 people helps, but I would suggest doing some hand stretches, cause youll be pumping like a wild man. After talking to him it only took me about 10 minutes
Old 02-04-2010, 09:55 AM
tk353's Avatar
tk353
tk353 is offline
dont forget to clean the pistons
http://www.lyndallracingbrakes.com/
Old 02-04-2010, 10:04 AM
PistonPuller's Avatar
PistonPuller
PistonPuller is offline
I bought a cheap one man bleed kit at HF for $4.99. It took 20 min. No mess, no other person, just me a plastic bottle and clear hose. Easiest bleed job I ever done
Old 02-04-2010, 10:20 AM
KumaRide's Avatar
KumaRide
KumaRide is offline
Perfect timing for this thread. Good idea, HF rocks for this kind of stuff.
http://www.harborfreight.com/cpi/cta...emnumber=37201
Old 02-04-2010, 11:44 AM
trooper_355's Avatar
trooper_355
trooper_355 is offline
Default Lines
Can they be bled down to the front brake like a car? Im going to change my cable when I swap bars.
Quick Reply: what tools to bleed brakes ?
